  1. i used to capture video from my tv card based on bt848 with powerVCR
    and i was very happy with the results.
    my system was a P4 1,7GHz CPU on a QDI PLATINIX 2A mobo ,512 sdram memory and a 80gb WD hard disk running windows XP pro.
    today i changed only the mobo with a MSI 845PE MAX2 and a new DDR
    512MB memory,the CPU,HARD DISK etc are the same.
    i fixed up everything and all works fine,all except ..POWER VCR!!!
    NOW AFTER ABOUT 5-10 MINUTES OF CAPTURING THE PREVIEW PICTURE
    FREEZES AND COMPUTER HANGS.
    THERE IS NOTHING I CAN DO BUT TO RESET PC.
    i tried everything i know,playing with IRQs,with BIOS,i changed PCI position,tried differend drives for my bt848 card..
    no matter what i do the problem still the same...
    please help.
  2. well well
    finally solution was very easy.
    i noticed that iuVCR had the same problem so that was a driver issue.
    i installed conexant bt848_hi res drivers and everything works now.
    thanks for your help.
