  1. Hello,
    I'm looking for info on authoring tools capable
    of dealing with XVCD and/or SVCD ?
    Seemingly, most authoring tools cannot do it.
    From what I have read so far only Nero and
    VCDEasy can.
    Has anyone else tried some other software
    such as Ulead DVD Movice Factory? Ulead
    DVD Workshop? Others?...
    Thank you in advance!
    Luis
  2. Member twodogs's Avatar
    Dec 2002
    Australia
    When you say "dealing with" I assume you mean create, so:
    http://www.vcdhelp.com/tmpgencxvcd.htm
    which is in the Convert section to the left.
    Use Nero only for what it is - burning software
    "speed's just a question of money. How fast can you go?" - Mad Max, 1979
  3. Hi,
    Yes, I was meaning authoring & burning. Since I have
    already coded the AVI's to MPG (XVCD). Nero seems
    to be a nice tool to use. Yet, I'd like to know about
    *other* tools that have *more* features (e.g. cool
    templates as Ulead DVD Movie Factory).
    Thanks,
    Luis
  4. Ulead DVD Movie Factory handles X/S/VCD. Make sure you get a current version. There was a sync bug in the first version; a patch is available though.
  5. Hello furball6969,
    Thank you for your reply. It's been helpful indeed.
    Now, I would like to ask one more question...
    Do you know if that software allows overburning?
    I ask that because I would like to burn a 90min
    and 100min cd, and I think I must use overburning.
    I Ulead DVD Movie Factory can't do the X(S)VCD
    *and* overburning, do you know of any other soft?
    Nero, VCDEasy... others?
    Thank you in advance,
    Luis
