Hello,
A growing number of dvd players can actually play
dvd-vcd and dvd-svcd, that is, as far as I know,
vcd's or svcd's that have been burnt in a dvd.
However, I'd like to ask: Has anyone tried to
burn a XVCD or XSVCD to a DVD successfully?
By successfully I mean playing it on the dvd player.
I also mean no editing, that is, no converting from
xvcd to vcd or xsvcd to svcd, since then we would
get a dvd-vcd or dvd-svcd and I'd like to get a
DVD-XVCD or DVD-XVCD.
I guess this might be dvd player dependent.
Thank you in advance!
Luis
"dvd-XVCD" and "dvd-XSVCD" should work fine. DVD supports mpeg1 and mpeg2 video and if the resolution is within the dvd standard it should be fully dvd compatible (you must change the audio to 48 khz).
Hello Baldrik,
Thank you for your reply.
Yes, that's why I was asking. Since anything X is out of
the standard (but within the DVD standard I guesss), I
was wondering.
In my case:
pure VCD:
352*288
XVCD:
video: 2035 kbs (fine bitrate for a 100min cd-r)
audio: 128 kbs
Do you think that would fit _within_ DVD?
BTW, does changing the audio from 41.100 to 48000
imply audio and video desynchronization?
*Thank you* in advance for your reply,
Luis -
It should work just fine, sunmanking!
352*288 is a legal PAL DVD resolution, and bitrate is ok too!
resampling from 41.100 to 48000 should not desynchronize the video and audio, just make sure you do it the way described in the guides on vcdhelp.com, to make sure you don't loose to much quality, or risk audio and video desynchronization.BTW, does changing the audio from 41.100 to 48000
Good luck!
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
