  1. Can you put svcd to dvd-r/rw using a cd burner? or do you have to have a dvd burner?
  2. Member Treebeard's Avatar
    Aug 2002
    it doesn't matter what your going to burn on the DVD media -- you ALWAYS will need a DVD burner.
    You didnt actually think the answer could be yes did you?
