Hi,
Using DVD2SVCD with VCD settings. Doing a 3 hour movie ended up with 3 images ready to burn to VCD with Nero but the 1st image is 81 minutes long even though Nero imports it as 79 mins 48 seconds.
I havent deleted any of the files DVD2SVCD makes and i was wondering if there something i can do to recreate the BBmuxed files a little smaller from the files i DVD2SVCD has already made rather than running the entire program again and reducing the amount per disc.
Any clues guys and gals would be much appreciated.
Gary
Have you tried burning the image anyway to see if it works? Sometimes various programs calculate time in a different manor and you get minor differences.
U need to set nero up to overburn your disc. in nero's options you can specify how far to let nero overburn like 81min 55sec. then when you hit burn it will say disc to small ! cancel or create overburn cd.
u should have no probs.
Delete Source Files after batch process has ended
By Metallo in forum Video ConversionReplies: 3Last Post: 24th Mar 2010, 19:10 -
Converting to RMVB from AVI, ended up with a bigger file?
By ianlin in forum Video ConversionReplies: 1Last Post: 12th May 2009, 14:03 -
VCD to PSP - Audio out of sync in last five minutes
By BozQ in forum Video ConversionReplies: 6Last Post: 2nd Apr 2009, 23:43 -
How I Ended Up Saving My Data From A Dead Drive...!
By tug_hill2 in forum ComputerReplies: 2Last Post: 25th Aug 2008, 11:56 -
As the Pats ended perfectly their season,...
By moviebuff2 in forum Off topicReplies: 9Last Post: 3rd Jan 2008, 06:51
