What is the Header Trick exactly can someone please try and explain what its supposed to do?.
patsym1
To find out about the header trick, go to:http://www.vcdeasy.org/modules.php?name=_Guides&id=VcdTrick. Esentially, the trick fools your standalone DVD player into thinking that an SVCD is a VCD and is therefore playable. In my experience, I have found that either the player will play SVCD's or it won't, regardless of header. I have not had much luck finding machines that are fooled by this, but maybe you will have some luck. 8)
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 08:41 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
All captured video has "Corrupt Header"
By raihnman in forum Capturing and VCRReplies: 2Last Post: 8th Mar 2009, 15:52
