  1. After ripping movie only portion, if the movie is under 4.7 GB, I would like to just burn these files without stripping extra content, due to time it takes. The normal method I use is dvd decryptor to rip files, then cut out extra content (languages, menus.....) with IFO_Edit. Then at the end I select get VTS sectors and it updates my Ifo files and bup files. Is there any way to just create these files after ripping with dvd decryptor?????
  2. Member wulf109's Avatar
    Jul 2002
    No,ripping programs in movie mode don't create the required ifo files. Ripping programs do offer a stream rip mode which if used elimintes the need to strip in Ifoedit. If you strem rip you'll only need Ifoedit to create the ifo files.
  3. So you are saying that I can rip just the movie portion in "stream" mode, then use IFO-Edit to create ifo files, then burn without ripping the extra content using ifo edit? If so, how do I use this stream mode? I've never tried it this way because I haven't known how. Thanks for the input.
    Jul 2002
    Lancs, England
    IF AFTER RIPPING THE VOBS IT IS UNDER 4.3GB YOU CAN START IF0-EDIT,THEN HIT CREATE IFO's CHOOSE THE 1st VOB FILE YOU RIPPED SET YOUR DETINATION FOLDER AND HIT GO AND THEN 10/15 MINS LATER YOUR GOT YOUR NEW IFO & BUP FILES AND ARE READY TO BURN.I TOO USE THIS PROCESS IF I CAN,USING SMARTRIPPER AND IFO-EDIT-95
  5. Member wulf109's Avatar
    Jul 2002
    In DVD Decrypter select ifo mode,you'll see two tabs,Input And Stream Processing. Change to Stream processing tab,click enable Stream processing,select the streams you want to include and click the rip icon.
