Really strange,i cannot separate the main movie to the initial trailer using dvddecrypter! I got the VTS_01_0.VOB including the f*** trailer,
but surprise, DVD2AVI encode the ac3 without the trailer!!!
so at the end i have:
*. ac3 regolar time
movie.m2v trailer+movie
so the film is LITTLE bit out of syncro, about 15 min!!!![]()
Is the first time that I have this situation. and is not my first rip movie.What I should do?
can I cat the trailers manually? (ok maybe yes but for syncro with ac3???)
software using
dvddecryper
dvd2avi
tmpgenc
chaterxtractor
dvdmaestro
gear6.3
tha movie in question is: showtime
any help?
Tix,
I am trying to decipher your POST, I am a bit confused. "separate the main movie to the initial trailer " HUH? You mean 'from', You got VTS_01_0.VOB , which is the Menu VOB, probably with the Trailer in it, you could simply use IFOedit to remove the trailer VOB ID. Please could you repost your specific question again and how you are ripping? I dont mean to insult you, but is your primary language english? Theres not enough information to properly answer that post...Thanks...
Vidhack -
Oohhhh, using SMARTIRIPPER i got the movie without trailer!
Why? cause smartripper is better than dvddecrypter?
I really have no idea. Anyway, the problem is solve, but i would like to know why this happening.....
bye -
yes, smart-ripper is better, in a way....
for example, if u use rempeg to de-encode,
the dvd2avi isnt needed....plus u can strip
chapters if needed...and u never mentioned
which dvd ur having trouble with,maybe someone
else is also....just a thought -
Originally Posted by VidHack
Ok the problem is solve, but normally I'm using dvdecryper setting at select main movie files and after abou 12 dvd's movie that i rip, i got one with the trailer including on the first vob file. But i discover later, after demuxing audio e viedeo.....in 5 hours.
is a firs time tha i get after the encode:
trailer+movie track
audio track (without trailer track!!!)
normally i get:
movie track
audio track
I hope my eng was better this time
tnx
Movie Trailers?
By xxnonamexx in forum EditingReplies: 4Last Post: 5th Nov 2011, 14:02 -
Movie Trailers in Quicktime
By skorpinok in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2010, 11:39 -
What other programs can separate main movie from extras of a Blu-Ray ?
By mahogany in forum Newbie / General discussionsReplies: 4Last Post: 23rd Aug 2010, 10:55 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
How to full backup (no encoding) BR main movie, main audio with subtitles ?
By meico1234 in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2009, 03:37
