Is it possible to do the VCD Header trick with Maestro instead of Spruceup? I have no problem doing it in Spruceup, but with Maestro, every time I save my project, convert the .m2v files back to 480x480 and re-enter Maestro it crashes.
I assume the "VCD Header Trick" you mean using MPEG-1 headers on your MPEG2 file... keep in mind that SVCD resolution (480x480) is an illegal DVD resolution, and probably what is causing Maestro to crash. I'd be interested in hearing about your SpruceUp projects... did you test them on your playe?
The closest legal resolution to SVCD is that of 1/2 D1 (352x480), the same used in CVD. Try encoding (re-encoding possibly, I'm afraid) in that size, and you don't need to perform any header trick, Maestro will accept them as standard DVD resolution video streams. -
Never mind, I found my answer here: http://forum.doom9.org/showthread.php?s=d9ed44be079c58296a2ad637be7f7827&threadid=1394...k&pagenumber=1
I have been successfully doing this with SVCD files, using TMPGEnc to reencode audio, DVD Patcher to change header information and DVD Maestro to compile. No problems with DVDMAestro.
Turns out my crash problem was due to the menu I created which used a clip from the movie. So for anyone else out there doing this stuff, dont use clips from the movie in menus if you're doing the SVCD header trick.
I had forgotten that I had done that.
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 09:41 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 21:50 -
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 20:01 -
All captured video has "Corrupt Header"
By raihnman in forum Capturing and VCRReplies: 2Last Post: 8th Mar 2009, 16:52 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 09:08
