Hmm, I'm new to DVD Maestro, I have been using IfoEdit to do all of my authoring but now I have a nice little intro I made that I would like to start adding to my DVD's...... problem is IfoEdit doesn't allow more than one video when it authors, so I switched to using DVD Maestro.....
Problem is, when I use it..... after a few minutes, or always anytime I try to import my chapter list it hangs..... completely hangs Windows and I have to restart??? Any ideas?
This is on a 1.4Gig T-bird in an Abit Kg7 Raid ...... 384Megs Crucial DDR.... Windows XP PRO with SP1....
I noticed that it locks up when u try to add chapters to ntsc films, but works ok with pal
Hmm, I don't have any PAL vids here.... everything is NTSC. It also "as I stated briefly" locks up or causes weird image problems in windows after just being open for a time limit of say about five minutes or more......
It's like it slowly causes Windows to become corrupt, the icons will start missing, text in Windows explorer will start missing??? When I go to shut it down the Shutdown box is clear, all you can see are the buttons??? Just really weird things. But it only does this when I usse Maestro.......
What OS are you using? -
well i would say first to make sure the dongle is properly plugged in - but i doubt that is your problem ..
make sure you are using the latest last version and it runs fine on XP , i am using a legal copy of it on XP machine with no problems.
i suppose you could try NT4 compatability setting for it in XP .. -
Originally Posted by BJ_M
But I'm not sure what the newest version is??/ The version I have is: 2.9.2915a
I will try the NT4 compatability, I have only tryed 2K compatability at this point.... I also have Cinemaster 2000 Dvd Player installed for it, you don't think that could be causing any problems do you??? -
no -- the cinemaster 2000 player works ok with maestro in XP as is (though otherwise its not a great product) ..
the version you are using is the latest common available version.
did you try to re-install it ?
it really has no issues at all with XP otherwise. -
I got it!
Turns out just a few hours later my whole XP install went freaking nuts. I must have had some corrupt system files. I did a repair install and now it is running just fine!!! I have completed my first movie with it but nw I'm having the same subtitle sync problems as stated here: http://www.vcdhelp.com/forum/viewtopic.php?t=136562&sid=b7fab62b2852f146c14b337a91071b7f
If I can just get this part figured out I will be very happy with this method......
Win 7 x64 Pro misreported disk space
By magillagorilla in forum ComputerReplies: 1Last Post: 14th Apr 2012, 21:58 -
Win 7 Pro install on multiple computers
By videobread in forum ComputerReplies: 1Last Post: 11th Nov 2011, 14:33 -
VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
By Rich_A in forum SVCD2DVD & VOB2MPGReplies: 21Last Post: 2nd May 2011, 15:06 -
DVDDecrypter work in Win XP Pro x64 w/ external drive?
By redsandvb in forum DVD RippingReplies: 8Last Post: 14th Jun 2009, 19:15 -
How to in Adobe Premiere Pro 2.0 (Win)
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 2nd Oct 2008, 19:45
