I've been trying to convert AVI (made with Ulead 720x480 NTSC) files to VCD/SVCD (TMPGEnc 12J) for the past month.
I've had no problems with VCD, but with SVCD it's a different story.
I've noticed that if i go higher than 352x240, when there's a change of scene (or when somebody moves there hands) ghosts lines appears until the scene movement stops.
Is this normal ? I'm using the original templates with the settings in the «How to» section of this site.
I appreciate any help
Thank you
Try the ghost reduction filter in TMPG or if you use VirtualDub, try a blur filter.
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
Strange Ghosts on mp4 movie
By PistolSlap in forum Software PlayingReplies: 9Last Post: 22nd Apr 2010, 11:43 -
Lines across DVD picture...
By xichael in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2008, 08:36 -
why do mpegs play with green flashing lines obscuing the picture??
By cyberraga in forum Software PlayingReplies: 1Last Post: 13th Dec 2007, 15:57 -
Lines in picture, HDTV PCI Card
By dnbrvr in forum DVB / IPTVReplies: 1Last Post: 2nd Dec 2007, 10:58
