  1. My computer (P4 2.8Ghz, 512Mb ram, 360Gb hd) slows down when I am burning ... I have DMA enabled... CPUload is very high.
    This began when I upgraded the firmware to 1.0f ....
    And Every CD-r I burn.. goes to hell... It seems OK in the burningprograms, but When I try to use the cds .. they are coasters...
    Please help
    Nov 2002
    Enterprise, Ms. USA
    From what i have been told when burning you need to disable your screensaver and don't do anything else with your computer since it uses so much of your resources to burn......spsp2
  3. I built a PC just for DVD writing. I use my other systems for gaming or browsing. I do computer repair and many systems I see have 10 million things running on them and other issues. I can only imagine howmany problems people have are due to this.
    Dec 2002
    Atlanta
    I have an Athlon 2200 with 512 mb of memory. I haven't noticed a large speed reduction. However I would recommend playing games while burning. What OS are you running? What program are you burning with? I have made DVD+R, DVD-R, cdr and cdrw with mine, no coasters.
    I run Win2000 Pro and use both the upgraded software that shipped with the drive and Nero 5.5
