so far, i've noticed it in 2 movies (region 1): black mask 2 and XXX
the original DVD has forced captions that appear automatically when foreign language is spoken (jap in black mask 2 and russian in xxx)
however, using vobsub/vdub and flaskmpeg, i can't find any subtitle track that contains these forced subs
even when playing the original DVDs in winDVD, i right clicked and looked at the subtitles available and i don't see any forced subs either (with previous DVDs, there's usually a labeled forced captions track that's automatically checked, but w/ these 2 movies, the captions are DISABLED, yet forced captions still play)
anyone know where these forced captions are????
as of right now, the only way i can get these to show up is to manually edit the .idx file from closed captions (not forced) from vobsub so that only the forced subs show up..but this is getting tedious and i'm not sure i can get all the forced subs to show up correctly
I've tried backing up the R1 version of XXX to SVCD and have the same problem...where are the forced subs?
There are english and french subtitle streams but i can't find the forced subs.
Does anyone know where they are????
Waylander -
yea...so far, the only thing i can do is take note of when the forced subs pop up in the original dvd. then when using vdub/vobsub, i manually edit the .idx file of the english closed caps by deleting the timestamps of all the caps except for the forced caps, but it's quite tedious, because i have to make sure i only leave the forced caps and delete all the othersOriginally Posted by Waylander076
Found this over on Doom9..going to give it a try tonight.....
XXX has 32 "forced" subtitles embedded in the English subs stream. The way I see it:
1. Open Subrip 1.14,check: Action, save as BMP. Open the ifo DVD2SVCD made, the program will say "Closed Caption detected (1X)".
2. Go to Global Options, check "forced subtitles only"
3. Rip them and save the text file.
4. Compare these to the ones DVD2SVCD made, and delete all that you don't want. I think that this will work.
5. If you use selectable subs, run crash recovery. If perm, you have to start all over. -
another way to go if the forced subs aren't on a separate subtitle stream....(from doom9.org)
http://www.doom9.org/index.html?/forcedsubs.htm
To do that open the .idx file that VobSub created when indexing the subtitles. You can open that file using a regular text editor, like Notepad.
Once opened look for the following entry:
# ON: displays only forced subtitles, OFF: shows everything
forced subs: OFF
Replace OFF on the 2nd line with ON, save the file again and you're all set. -
Or alternatively there is the easier option of opening Sub Rip 1.14
and selecting the 'Forced subtitles' option and it will rip them
that way.
Regards
Waylander -
well....subrip isn't necessarily "easier" if ppl are used to the vobsub/vdub method. the .idx produced by the latest vobsub has a line in the file that allows you to only display the forced subs...so you basically just change from "OFF" to "ON". the good thing is that all the subs are still there in case you change your mind and want to add all the subs. all you need to do is to change it back to "OFF"Originally Posted by Waylander076
forced subtitles
By bogey219 in forum SubtitleReplies: 4Last Post: 6th Nov 2011, 21:00 -
Forced Subtitles
By sxj1704 in forum Blu-ray RippingReplies: 4Last Post: 29th Jan 2011, 08:17 -
Weird, very weird thing demuxing a DVD
By jairovital in forum EditingReplies: 17Last Post: 22nd Oct 2010, 18:31 -
How easy are forced Subs?
By stephens in forum SubtitleReplies: 0Last Post: 6th May 2010, 12:19 -
The Mummy - How to get the forced subtitles
By Mascot in forum Blu-ray RippingReplies: 19Last Post: 20th Apr 2009, 20:01
