Hi,
I have this problem with the audio, I get alot of noisy sound when a very bright scene appears or sort of whitish frame appears. Picture quality is perfect, just dunno how to remove those noises. Is there a software available that can reduce the intensity of those sounds without dsturbing the rest of the audio? Help me guys![]()
Can you send me 10 secs of your audio (with normal audio and the noise)?
I'll check it and see, if CoolEdit can remove it! -
Whenever I get clicks or "chirping" sounds due to video tracking errors or old tapes I use wavepurity. It will clean the audio without noticably affecting the "good" sounds.
Remove Voices And Background Music From A Video
By DigitalDummy24 in forum AudioReplies: 5Last Post: 6th Mar 2010, 01:07 -
How to remove a shadow from the white background in the still image?
By coody in forum EditingReplies: 1Last Post: 15th Aug 2009, 23:38 -
reduce background noises in a movie clip
By tomchook in forum AudioReplies: 1Last Post: 5th Jun 2009, 05:55 -
Strange Audio noises..
By Superstar24 in forum Newbie / General discussionsReplies: 3Last Post: 29th Nov 2008, 02:12 -
noises in audio
By Driftking978 in forum AudioReplies: 1Last Post: 29th Apr 2008, 10:51
