Hi guys,
Every time i try to do the full process making an XVCD with EASY VCD in BIN/CUE format, it only ends up burning the folders & you cannot open these to play anything? It strips & reads the DVD fine and goes through all the process but when i finish burning it only shows folders?
i also tried using the MPEG format way and it never shows up with anything when i try to burn, i can't see any image to burn onto the disc?
i was wondering if anyone could please help me out, quite frustrating
thanks in advanced for any help, all responses are takin into consideration
B-boy
My system is xp 2100+ - WIN XP ( service pack 1)
512 DDR Ram - Lite On 16 x writer & Pioneer AO3 DVD writer
incase there is any wonders in specs,
thanks again
Doesn't anybody have any idea's of what it could be? any help would realy realy realy be apreciated, sorry gettin desperate as i have wasted many cd's trying to figure it out.
thanks in advance
B-boy -
ok, when you do the BIN/Cue way the folders on your CD-R are normal
Your set top DVD Player needs it in this format to play propley
if you want to watch it on you PC, go into teh folder named MPEGAV and open the .dat file in media player.
If you do it the MPEG way,
you will need to follow the guide in the HELP/FAQ section to see how to burn the MPEG file to CD-R.
Rob FErgusonDVD to VCD made eazy
http://www.eazyvcd.tk
Multisession DVD Burner and Burning Files into Specific Folders
By Disco Makberto in forum ComputerReplies: 9Last Post: 23rd Feb 2010, 02:48 -
Burning multiple remuxed folders to discs, playable as dvd
By blue2 in forum Authoring (DVD)Replies: 6Last Post: 8th Oct 2009, 10:05 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2007, 00:54 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
