Whats the way to do this? I've backed up some of my DVD's, so I'm familiar with how to do this, but I can't seem to find any guide on taking a downloaded file, and turning it into .vob files that I can use to author a dvd-r with.
I've tried using VirtualDub, but that seems to want to encode the files into a Div-X type format. From my experience with DVD's, I want to extract them into .AC3 and .M2V so I can feed them into Maestro to author.
Thanks!
You might want to avoid out for Maestro, it's a mother to learn. But check out the guides here, esp
ripping
encoding
authoring
burning
and that sort of thing -
As these are downloaded mpegs I am assuming they are VCD compatible mpeg1. You can create a DVD-VCD, follow this guide.
http://www.vcdhelp.com/vcddvdr.htm
downloaded video file, has buzzing audio when put into encoder
By efiste2 in forum Video ConversionReplies: 3Last Post: 22nd Jun 2009, 12:55 -
Put many avi files onto DVD
By Airjrdn in forum Authoring (DVD)Replies: 8Last Post: 23rd Apr 2009, 22:45 -
Downloaded VOB, BUP IFO files won't play in dvd player
By COOPERMAN100 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 05:31 -
how to put music mpeg onto dvd
By GroovyGran in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2007, 06:38 -
Can I put multiple video files onto one DVD?
By flameout in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2007, 15:12
