Most of the VCD's/SVCD's I download are posted with an .nfo file. I'd like to be able to include the .nfo file somewhere on the disk.
If I drag the file into the root directory, will it screw up the disk once it is burned? I'm using Nero.
You can add iso files to vcd and svcds. It should work ok to put it in the root but don't put it any other standard vcd/svcd folders.
Can you rip a dvd without the menu requirement...plz read for nfo.
By darkcyber in forum DVD RippingReplies: 5Last Post: 11th Jul 2011, 22:45 -
Which video file format can include metadata, like keywords, description et
By dumbletore in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2009, 23:10 -
Subtitles stored inside AVI File
By Maikeru-sama in forum SubtitleReplies: 4Last Post: 25th May 2009, 08:31 -
Display subtitles inside a divx file
By renzord in forum SubtitleReplies: 8Last Post: 2nd Nov 2008, 12:46 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 22:06
