I am using a long tutorial that has you go through the following basic steps
1. Rip the DVD
2. DVD2AVI to create the .wav and .d2v
3. Convert the .d2v to .avi using VFAPI Codec 1.04
4. Convert .wav to mp2 using toolame
5. Virtual Dub
6. TMPGEnc
7. bbmpeg
Problem is, I am getting a error that I have never seen before. When I go into the VFAPI Codec 1.04 I am getting the error "???? E:\DVD\moviename.d2v ????"
Any ideas?
Did you update to a newer dvd2avi version and do you try to convert a project, that is made with an older dvd2avi version?
Nope, same versions that I have always used.
I just am trying to do it on my Win2K machine but as far as I know, these programs should work fine on Win2K
Do yu still have your vobfiles in the same spot they were in when you made the d2v file?
I had this problem before. Just re-create the D2V file again.
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 06:40 -
VFAPI Reader Batch convert?
By Totta in forum Video ConversionReplies: 0Last Post: 20th Sep 2010, 11:44 -
VFAPI and Windows 7 64 Bit
By JekhoOne in forum Video ConversionReplies: 3Last Post: 21st Apr 2010, 13:56 -
Is there VFAPI Alternative (For Windows Vista)?
By foochuck in forum DVD RippingReplies: 16Last Post: 4th Nov 2007, 19:02 -
VFAPI problem on Windows Vista (Home Premium)
By foochuck in forum Video ConversionReplies: 1Last Post: 3rd Nov 2007, 18:10
