hi hope someone can help got an AVI file that i want to encode for dvd in
TMPEGnc have been using befor and it went wellbu this time i tried to use it i keep getting error message coming up a lot of numbers does anybody have any ideas
If TMPGEnc freezes or crashes when converting or you receive errors such as
Unexpected decimal point calculation
Illegal floating decimal point calculation order
Try first to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
Or try to convert the audio to wav before converting(If you have problems extracting the audio using Virtualdub try use Goldwave or AVI2WAV).
Or try to repair the AVI,DivX or the ASF.
Or try to use avidefreezer to fix your video source.
Hope That Helps!!!
:P
thanks for your reply ill keep itin mind i just got the latest version of TMPGEnc and have run the same file again and it seems to be ok but sods law says ill need your advice sonner rather than later
thanks for talking the time to reply
Ripbot errors
By Benjy in forum Video ConversionReplies: 2Last Post: 21st Dec 2009, 08:03 -
Replacement for TMPEGnc DVD Author for the Mac?
By The Monkees in forum MacReplies: 1Last Post: 24th Feb 2009, 14:36 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
AVI File Not Supported by TMPEGnc?
By The Monkees in forum Video ConversionReplies: 5Last Post: 3rd Feb 2008, 19:26 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 11:53
