i am a newbie and been using the trial version of tmpgenc to encode amovie but it took a whole day for a 2hour movie,is this normal?I have a Pentium 3 455mhz 128Ram with windows Me ..
Yes, considering your system specifications. Prcessor speed is one of the key factors in encoding with TMPGenc. I have a "fast" system and I would guess that if I used the same file and settings that you used (no matter what they are) my system would probably do the encoding in 2-4 hours.
My system would take 2 hours for vcd and 7 hours for dvd
Will
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
Does anyone have a preset for 1:1 encoding ratio with tmpgenc plus ?
By LordVader in forum Video ConversionReplies: 3Last Post: 9th Dec 2009, 09:21 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23
