Results 1 to 12 of 12
    Sep 2000
    Ga Usa
    i was wondering where to purchase 90mins cds. and if the double sided cds every came out?
    thanks
    Sep 2000
    Ga Usa
    sorry didn't see post below
  3. you can get 90 min cd s on the net
    ive tried them...dont like them , you ll find once you use them that a lot of readers or writers wont be able to read them. if you plan to use em just for yourself then they re great though!! ( if your writer supports them )
    i saw a link on this very forum for double sided cdr s , if you have a search back ..i m sure you ll find it
    <font size=-1>[ This Message was edited by: BIGTHREE2001 on 2001-09-03 02:48:39 ]</font>
  4. Let's stop some rumour.
    Double-side CD-Rs DO NOT exist.
    Indeed, they CANNOT exist without violating the physical dimensions of a CD (thickness). That, or someone will have to invent a replacement material to serve the same function as the polycarbonate platter but with just the right refractive index (doesn't exist).
    Regards.
    Michael Tam
    w: Morsels of Evidence
  5. ah so ...that link i saw must have been bull then.
    i m not saying they acctually exist ...i m just saying i saw something about them the other week on the forun
  6. You can buy 90 min cdr's from http://www.121cdr.co.uk, I've used them loads of times and the service is excellent.
    Jan 2001
    Vancouver/Portland
    The 90min CDRs available on the market all use poor dye, which makes them cheap/bad cdrs. I bought some from shop.disc4you.com and yeah, they work and all. But they will probably get ruined (and become unplayable) within a few months.
    I saw some 90mins at CompUSA recently, try there (even though CompUSA makes the worst CDRs out on the market).
    Just for the record, the 90min CDRs play fine on my Pioneer DV-333. =)
  8. Why bother to look for 90 min CDR. using Tmpge encoder You can have 100 min movie on 1 80min CDR
  9. MABE SO...
    BUT I BET THE QUALITY IS CRAP!!!!
    THE ONLY WAY TO FIT A 100 MIN MOVIE ONTO A 80 MIN CD IS TO COMPROMISE THE QUALITY
    THEN WHAT S THE POINT..YOU MAY AS WELL PUT IT ON TO VIDEO.
    Oct 2000
    Prescott Valley, AZ, US
    On 2001-09-05 00:21:34, BIGTHREE2001 wrote:
    MABE SO...
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Sorry, that just is not necessarily true. The VideoCD standard is MPEG-1 CBR. Using Sefy's SxVCD templates, I was able to get 80 minutes of video on an 80min CDR. By using MPEG-2 VBR encoding, very, very little quality is lost. And can hardly be considered crap.
    I can see with judicious tweaking of settings that it would be possible to get around 100 minutes of video on a single 80 min. CDR with VCD-comparable quality.
    VBR makes a significant difference because it only uses higher bitrates when needed...and drops down where appropriate, making intelligent use of space.
    Jul 2001
    I heard something about Sony making Double Density Cd-R's of over 1 GB, could it be this is what you heard?
    Sep 2000
    Ga Usa
    yes i herd that too about gig cds. i wnated 90minis cds so i wouldn't have to encode xvcd b/c my vcd player doesn't support it.
