How to convert MiniDV files avi or some else files to DVD format
i want to backup my materials form MINIDV to DVD
thanx
Pioneer DV 717
Pioneer DVR 108
Sony RDR-GX3 -
Technically, the files are not MiniDV, that's just the tape format. Assuming you captured from yoru cam with firewire, you will end up with DV files, same thing with Digital8 DV cams. MOST Windows programs capture to DV AVI files. They are lower field first. Encode away with your favorite encoder with that in mind. Some programs allow you to capture, edit, author, compile, and burn all in the same applications (such as Pinnacle Studio 8.)
moved topic to capturing - MiniDV to DVD-R is not DVD to DVD-R
Panasonic DMR-ES45VS, keep those discs a burnin'
How to convert MOV files created by a Kodak digital camera
By peliopoulos in forum User guidesReplies: 19Last Post: 21st Sep 2012, 11:31 -
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
Is still worth to buy a miniDV camera?
By Soulman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 4th Dec 2007, 20:00 -
looking to buy a used Minidv Video Camera
By crocker5731 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 24th Aug 2007, 12:10
