This is a spin-of of another topic I originated...
"Need Help capturing at 640x480 w/ ATI All-in-Wonder"
PIII 800mhz
500 MB RAM
7200 RPM 13GB HD (DMA Enabled)
XP Home SP1
ATI All-in-Wonder Radeon 7500
Sound=Sonic Impact S90 (Aureal)
What would cause my system to allow me to capture at 33.66 but not 29.97? I drop frames like crazy at 29.97, but 33.66 seems relatively stable. The only problem is that the audio gets way out of sync.
This is using VirtualDub in "Compatibility" mode at 33.66. When I set it to capture at 29.97, the "Average Frame Rate" still hovers around 33.66. If I set the rate to 15 it hovers around 20.1.
I get the same results WITH or WITHOUT capturing audio, so I doubt it's my sound card. I do have a VIA chipset motherboard, but I have installed the latest drivers.
Thanks in advance for any help.
PROBLEM SOLVED!!!!!!!!!
I applied the VIA PCI Latency Patch from
http://www.georgebreese.com/net/software/
and it fixed it!
f.y.i.
I have a Tyan Trinity 400 (S1854) which has the VIA Apollo Pro 133A chipset.
Mine was one of the chipsets listed on the above mentioned site that would benefit from the patch. I loaded it and boom! 640x480 at 29.97.
Just to be sure, I uninstalled the patch, rebooted, and sure enough the problem was back. The board would only capture at 33.66 even if set at 29.97. Reinstalled the patch and everything works.
Figuring out if different fps rates are actual reason for different times
By cinesimon in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2011, 22:53 -
Using Sony HDR-FX1 to Capture a Mini-DV @ 24 FPS
By foochuck in forum Capturing and VCRReplies: 3Last Post: 11th May 2011, 17:50 -
Very strange VHS to PC capture problem
By fredhoward in forum Capturing and VCRReplies: 45Last Post: 9th Feb 2010, 08:30 -
Capture - Colors, Fps problem
By Ytek in forum Capturing and VCRReplies: 14Last Post: 1st May 2009, 08:30 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
