I have 04 files (mpeg) which was BIN files that I converted to MPEG using VCDGEAR, Now Im wondering how can I put these files togheter (which software do I need?) I tried Final Cut Pro 3.02 but it gives me this error:
File error: Unknown file
Also I dont know how Am supposed to burn the file (s) on a dvdr(w) using toast. All I have to do is choose dvd from toast menu and drop the MPEG(s) file (s) and then burn?
Another problem Im facing is that I have a GI file (playstation2 dvd) which I have not been able to burn using my Mac + Toast... According to a friend there's no way to burn a GI file to a dvd on a MAc only PC, is that right?
step 1) collect underpants
step 2) ?????
step 3) profit
It's very simple really. I think DVDSP only works with mpeg 2 video to make dvd format disks (m2v video and ac3, wav, dts or pcm audio, plus subtitle streams). You could try to put toast in VCD mode and load up a DVD-R's worth of mpeg data and burn it, see if it works in VCD compatible DVD players. Never actually tried it myself.I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
dsp will take mpeg 1 streams with ac3 audio, i think it will also take mpeg2 streams at 352x480 w/ ac3 audio. but not 480x480.
pants -
That did not work
As for the GI file, do you know anything?
Im wondering if there's a way for me to burn the GI file using Virtual PC... But so far I have not been aple to burn dvd (on my pioneer 105)with it, just cd on another device (QPS)
m2ts to burn in Toast 11 (MAC) Issue
By Reesche in forum MacReplies: 3Last Post: 27th Sep 2011, 14:55 -
Toast vs. iMovie/iDVD which is better for Mac?
By HowardNeedsHelp in forum MacReplies: 13Last Post: 2nd Sep 2009, 10:42 -
Menu button selection order in iDVD vs. Toast 10 DVDs for MAC
By HowardNeedsHelp in forum MacReplies: 0Last Post: 29th Aug 2009, 11:06 -
I'm an idiot! How do I copy a DVD using Mac The Ripper and Toast 10?
By brido7760 in forum MacReplies: 2Last Post: 20th Jul 2009, 11:42 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 21:48
