Results 1 to 9 of 9
  1. I have a Sony 16x internal DVD drive and whenever i put in any recordable CDs, my DVD drive doesnt read it. My cdrom drives can read them just fine though. Anyone know whats wrong?
  2. Member Treebeard's Avatar
    Aug 2002
    When you say recordable media do you mean the cd is still blank?
  3. No lol, stuff is on the CD of course
  4. I have a similar problem with my I/O Magic dvd rom. Sometimes I have to turn dma off and when I do this the drive reads the cd-r/rw fine. I only have to do this for burnt cds. I turn the dma on for store bought dvds or cds.
    Also did you use packet writing type software (Adaptec's Direct CD or Aheads InCD) to create the cd or did you use cd mastering software (Adaptec EZ Creator or Ahead's Nero). Some dvd/cd roms have a problem with cd-rs that are written with packet writing software.
  5. I normally use Nero. Is there a way to turn off DMA mode for my DVD drive without entering BIOS?
  6. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    Try something different....Find on the web
    ASPICHK for version 4.60
    http://www.adaptec.com/worldwide/support/driverdetail.html?sess=no&language=English+US...ey=aspichk.exe
    Install and run
    ...If it says you don't have a VALID ASPI layer , then find
    FORCEASPI 4.60 (at afterdawn on a google search ) and install.
    http://www.afterdawn.com/software/cdr_software/cdr_tools/frcaspi.cfm
    Ignore about win xp..it works ...The best there is.
    Most CD rom DVD rom, flakey problems are ASPI related.....
  7. Originally Posted by arcorob
    Install and run
    Ok found out i didnt have any ASPI drivers so i installed FORCEASPI, but my dvd drive still doesnt read cdr
  8. Originally Posted by kenmo
    My current DMA mode for my DVD drive is 2. I tried disabling it but that didnt work either Another other suggestions?
  9. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    Let me ask a dumb question..You don't have any ROXIO products installed along with NERO do you ? They are incompatible. In fact, surprised nero has worked for you without ASPI (though it will with the ASPI file it has but results unpredictable)
    I had a DVD rom at one time that insisted on DMA off. But it was the drive.
