Page 2 of 2
FirstFirst 1 2
Results 31 to 38 of 38
  1. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    It works with my external firewire fine.
    Under XP here is everything you have to do to make it work.
    Install ASPI (I used force aspi)
    Install ADVinfo
    Put copy of aspi files into advinfo directory.
    Open adv info and select the drive with the disk you wish to check (must be a dvd burner for dvd-rs)
    in the pull down box select to read the pre record info. (dont have the exact wording in front of me)
    Click the button to read it. Thats it your done.
    Works fine for me through several formats so if that doesn't do it, well maybe you did something else wrong. Anyway like I said at the start I'm 100% sure it works on external firewire burners cause thats how I use mine.
  2. I'm running my DRU-500UL on USB 2.0 at home. I have the FireWire cable at work so I can be productive all day long . I'll try your method for USB.
  3. NEW APPLICATION.
    Folks,
    In consulation with >NIL: author of ADVINFO. I have written (writing) a replacment application called DVDINFO.
    This program is freeware. I am looking for feedback, suggestions, new skins, etc for the program. It supports both DVD-R/RW and DVD+R/RW.
    Have a look and let me know what u think.
    http://www.nicsoft.com.au/download/dvdinfo.zip.
    The program will work on Aspi V4.60 but V4.7.1.2 is recommended. (NOTE: V4.70 and V.71) do not work properly please update to V4.7.1.2
    from the adaptec web site http://www.adaptec.com
    cheers
    nicw (author)
    nicw
  4. Folks,
    I need some testers for DVDINFO V0.20. I have removed the requirement for ASPI. This required some major rewrite of some of the routines.
    The program is ready for testing. It should hopefully now work more easily and support external devices, this needs testing.
    If you want to test if before release please contact me via email.
    cheers
    nicw
    nicw
  5. Folks,
    I have released DVDINFO V0.20 to the site.
    NO MORE ASPI.
    I have manged to now work without aspi which is a big improvment.
    I have also added compatibility with external burners.
    Cheers
    nicw
    nicw
  6. folks
    Your wish has been granted.
    I have just uploaded V0.22 of DVDINFO.
    changes are.
    1. Complete media Code command added to list, this command crops data to 3 lines for minus and 4 lines for plus. Clipboard is also clipped.
    2. Moved 46h to top of list and renamed to Get Configuration Data.
    3. Made a sub-heading for other commands called "READ_DVD_STRUCT COMANDS" and moved all relevant commands under it.
    4. Fixed a bug in 46h not showing enough data.
    5. Fixed a bug that could cause a 5 second delay if error on media button.
    cheers
    nicw
    nicw
  7. Folks,
    DVDINFO V0.23 is out and up on the site.
    Those who requested max write speed of media, this has been done.
    changes are:
    1. Added max write speed to media info display.
    2. Added write rotation control type to media info display.
    3. fixed some minor graphical glitches.
    4. small code improvements and minor fixes.
    cheers
    nicw
    nicw
  8. Just to give you guys update on ADVDinfo (not DVDINFO nicw ).
    I can use it with Sony DRU-500A in externla FireWire case under W2000.
