Does anyone know how to convert Xvid (new divx format) files to svcd or vcd. I have been gettin these from British mac users (the only ones I have seen with them) and they have given me nothing but trouble. ffmpegX does not want to touch them and quicktime doesn't like them either (even with the proper codecs). I can however play them in vlc 0.4.6 perfectly.
Any help would be much appreciated.![]()
- Elreeko
"I have not failed. I have simply discovered what does not work." - Thomas Edison -
Thanks.
I'll look again. Couldn't find it on my last search.
- Elreeko
Although I am thankful for any information, I would like to note that this is a MAC VIDEO FORUM. Therefore TmpgEnc does me no good. I need a way to convert Xvid on a mac.
- Elreeko
Thanks.
I can play it in vlc too, but what I really want to do is play it on my tv as an svcd
- Elreeko
have you tried using mencoder to convert the Xvid to a different divx format? this has worked for me, and then you can run it through DivX doctor or ffmpeg/mediapipe/mpeg2enc just fine.
use the following syntax:
mencoder -ovc lavc -oac pcm /path/to/your/file.avi -o /path/to/your/destination/file.avi
I always choose PCM because it is fast as hell to convert to it, and you dont have to worry about encoding options. On my 800 G4, it converts faster than real time usually.
be sure to specify your output file as a .avi format.
Once you get the resulting .avi you should have no problems converting it to VCD/SVCD. This method works for Xvid, and divx files that have wma audio
Let me know if this works for you. -
Excellent!! That looks like it may work.
Thankya very much.
I'll let you know how it goes.- Elreeko
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 12:23 -
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 06:31 -
convert vob files of karaoke to xvid and still maintain the same chapters
By volam in forum Video ConversionReplies: 14Last Post: 14th Jun 2009, 21:50 -
Convert Xvid versions to Xvid 1.1.2
By mdavenport in forum Video ConversionReplies: 23Last Post: 11th May 2008, 18:01 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 10:55
