After trying to follow the tutorial SVCD to DVD and searching the forums for a solution I am desperate.
I demuxed an SVCD-file in TMPEG (there is no difference between a burned SVCD and a regular one I take it?! The tutorial makes me believe the author uses a burned file).
I converted the sound to 48 khz in ssrc (is there a difference between what bitrate I use - my file is 128, the author uses 224).
I changed the .mp2 to .mpa.
I patched the header with DVD Patcher.
I added the m2v-file in SpruceUp and it loads the whole file, and here comes the problem: When the whole file is loaded I get an error message saying there is something wrong with the mpa-file. I did it several times and I also tried the whole process over again.
Sweet.
What does spruceup exactly say? YOu could try reencode the audio with besweet.
It said "media error (some long series of figures and letters, looks like a memory reference) in XXX.mpa." or something similar. I tried to use toolame now and all that happened now is that at the end of spruceup's importing of the file, it said the last frame was incorrect, but that I could move on w/o it.
Sweet. -
I also often receives the last frame error. But it works fine anyway. I never received the other error you mention, it sounds like it is not mpeg audio.
It is the same file, so it should be mpg-audio. Hopefully I ll be able to share my experience soon, since this is the first time I author dvd from svcd. Btw: why do so many people think it is such a hassle doing it - it doesn't seem to be that big of a work load when u know how to do it?!
Sweet.
Problems with chapters in DVD authoring/audio temporarily off-sync
By nocomments87 in forum Authoring (DVD)Replies: 7Last Post: 9th Nov 2011, 08:44 -
Problems in authoring DVD
By carlmart in forum Authoring (DVD)Replies: 9Last Post: 1st May 2011, 03:48 -
Sync problems while authoring a DVD with DVD Flick
By TioSolid in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 13:21 -
FCP dvd authoring problems
By sksvideo in forum MacReplies: 3Last Post: 18th Mar 2008, 16:57 -
Problems with DVD Authoring
By Velocity_Girl in forum Authoring (DVD)Replies: 6Last Post: 27th Jul 2007, 05:34
