I have two DivX movie files I want to join using Virtual Dub. I've done this process several times before, but for these two files it doesn't seem to work. After I open the first file and then select "Append Video Segment" and choose the second file, it gives an error "Cannot append segment: The segment is not from the same video clip." I thought that perhaps since they were not encoded in the same video/audio compression schemes, that was the problem, so I re-encoded both of them to the exact same codecs and settings and it still gives the same error. Any ideas?
Hi
When you re-encoded them using the same codec, you still may have ended up with difference. Click your right hand mouse on them and select properties, this will show you the exact difference.
Or use Vdub File > File info -
Well I got everything the same except for the frame size. One is 352 x 240 and the other is 320 x 240. How can I change either of them to match in Virtual Dub?
Then use a filter > add > resize
Personally I would convert them to VCD.mpeg with TEMGEnc using a VCD template, then they will both be ready for VCD's -
I use Peck's Power Join for joining .avi files. It's faster, and it ignores some differences between files.
P.
Joining 33 avi files with vdub
By aruwin in forum EditingReplies: 3Last Post: 9th Oct 2008, 03:30 -
Joining Overlapping DivX Files?
By JDub2k in forum EditingReplies: 2Last Post: 25th Apr 2008, 01:14 -
Joining DIVX files
By jimbb in forum EditingReplies: 17Last Post: 9th Apr 2008, 11:05 -
Convert with super/ Joining with vdub?
By Jorge in forum EditingReplies: 12Last Post: 5th Feb 2008, 15:29 -
Joining AVIs - Vdub reports audio streams do not share common sample rate
By Lolipop Jones in forum Video ConversionReplies: 3Last Post: 22nd Jan 2008, 14:32
