  1. Can anyone please explain or direct me to a technical tutorial regarding the GOP structure in TMPEGEnc? I'm particullarly interested in finding out for what it is used. Will it affect the quality of the conversion if I fool with this option? Will it affect the size of the final MPG?
    The itsy bitsy spider climbed up the water spout. Down came the Goblin and took the spider out. -- Spider-Man, 2002
  2. Check out these FAQs:
    http://bmrc.berkeley.edu/frame/research/mpeg/mpeg_overview.html
    And send a message to user kwag, he is king of GOP twidling.
    Panasonic DMR-ES45VS, keep those discs a burnin'
  3. Thanks, Kitty!
    Mar 2001
    Antwerp - Belgium (Europe
    Quality also depends on GOP structure.
    For animation, this GOP is most suited : IBBPBBPBBPBBPBBPBB (1xI, 5xP, 2xB).
    For movies (not animation), this GOP is most suited : IBBPBBPBBPBB (1xI, 3xP, 2xB).
    For DVD, 2 types of GOP are mostly used :
    - IBPB (1xI, 1xB, 1xP)
    - I (1xI, 0xB, 0xP)
    When encoding using TMPGenc, also check the box 'Closed GOPs' : Some applications for building a S/VCD (lkVCDxBuild, VCDxBuild) can give problems when 'open' GOP's are used.
    May 2001
    - I (1xI, 0xB, 0xP)
    Not true... the DVD spec specifically states that "Low Delay GOPs are NOT permitted". Low delay means the absence of "B" frames (because of the way they have to be juggled in the player, there is a delay between the time they are decoded and the time they are played).
    I use IBBPBBPBBPBB for both live and animation encoding. Most Hollywood disks (that I've seen) use this GOP.
    Feb 2001
    Macondo, Puerto Rico
    will the I (1xI, 0xB, 0xP) structure give compatibility problems?
    Wil it affect the forward funtion in a dvd player?
    Regards,
    Jose Febus
