I recently obtained a SVCD of a movie from a friend however it contained bad frames due to it being burnt on poor quality media.
My question, how can I correct this? Is there a program, such as MPEG Corrector (only does MPEG1 correct?) that can scan the files and remove/fix these frames or a procedure I can use?
Thanks.
check out the guides section here i believe bronfire put a guide out on that topic...
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 17:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 12:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 03:39
