I managed to get a divx film onto dvd-r. The picture isnt as good as I'd expected after seeing the excellent quality on the pc. Should I use interlace or not? it seems quite 'blocky' in parts. Also its got a definate jerk which seems to be at a costant rate. Maybe this was caused in the conversion- original was 23.97fps (I'm in the uk)- when i previewed it in spruce up it seemed fine. Any info on settings please. It seems so close to being right, maybe this is as good as it gets?
If your DVD/TV will handle NTSC you should perhaps make a NTSC DVD not a PAL
You converted a NTSC (Film) @23.97fps to PAL @25fps, normaly NTSC at 29Fps is not so bad. -
You should not deinterlace cause divx is never interlaced. The best is to convert to 23,976 with 3:2 pulldown(=29,97 playback on your dvd). Use the tmpgenc wizard and choose ntsc and it will automatically be 23,976 with 3:2 pulldown. And use the highest possible bitrate and if the source is in a low resoulution(lower than 720x480) try use lower dvd resoultion also(352x480) cause resizing up video is never good.
But be sure that you dvd player and tv supports NTSC(most european players and tvs supports ntsc). -
Thanks for the replies. I just got a dvd-rw so I'll give them both a go on that & see which works best.
Jerky picture on DVD
By ANOther1676 in forum RestorationReplies: 1Last Post: 26th Feb 2011, 07:51 -
Jerky Picture and Sound on PS3
By det66 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 11th May 2009, 00:11 -
Jerky Picture and sound on PS3
By thumper66 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 5th Mar 2009, 11:51 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
DivX to Mpeg -> DVD Conversion is Jerky
By jedijfo in forum Video ConversionReplies: 4Last Post: 15th Oct 2007, 09:32
