After converting an AVI file to MPG in TMPGEnc I get some kind of small picture in the upper right corner of the movie. It looks like a "Renju chess board", white with some crossing lines on. The most upper right corner is marked black.
What the h... is that?
I tried both converting directly in TMPGEnc and frame serving from VirtualDub.
The movie was a small THX demo AVI to be used before the main movie as fun.
Did you convert to Mpeg 2 ?, sounds like its a trialwear of the Mpeg 2 filter, which you need to buy to remove it
or at leased don't install trialwear programs
KaZaA > Ligos -
Whatever you're playing it back with is using the Elecard direct show filter. Install a different mpeg2 playback software such as PowerDvd.
does it move at all, was it in the original avi?
it might be a timing device kind of thing as are often found on testing clips such as that..-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Vobsub causing pixelation on upper RH corner?
By Uzysuicide in forum SubtitleReplies: 2Last Post: 7th Feb 2008, 17:13 -
My DivX movies randomly blocking up only in the upper-right corner... (pic)
By sofakng in forum Newbie / General discussionsReplies: 6Last Post: 9th May 2007, 15:21
