The problem is if you have large file say Die another day which is about 1.4gb avi file is there a way to fit it on 1 dvd without comprimising the quality
Its all about bitrate. Check the length of the movie and use a bitrate calculator to determine the Avergae bitrate to use for the encode. This will give you the best quality achievable for a single DVD from that source file. Anything above 3500 - 4000 should be OK for most movies. Perhaps a bit higher for movies with LOADS of action.
I converted a large AVI to MPEG2 and everything looks/sopunds great. Now I want to burn to DVD, so I put the MPEG through SpruceUp. The Spruce export crashes every time. Any ideas?
My system:
Abit Ic7G
P4 3.0C @ 3.98 GHz
2x512 MB DDR 500 ram
WinXP Pro
ATI Radeon X800pro
5x120 GB Western Digital ata100
TDK Velocd 48x16x44
Sony 8x DVD burner
Problems converting DVD to AVI, MP4
By azikiwee323 in forum Newbie / General discussionsReplies: 3Last Post: 25th Jun 2009, 12:33 -
Having problems converting .mov to .avi
By ForevaYoung in forum Video ConversionReplies: 1Last Post: 8th Jan 2008, 10:40 -
Problems converting Multiple .avi files w/ subtitles to DVD
By bwanis in forum MacReplies: 2Last Post: 30th Nov 2007, 13:23 -
having problems in converting from h.264 to avi
By the deadman in forum Video ConversionReplies: 3Last Post: 18th Nov 2007, 10:08 -
Loads of problems converting avi etc. to dvd please help!!
By mrd2007 in forum Video ConversionReplies: 9Last Post: 14th Jul 2007, 12:53
