Hi guys I got some problems ripping dvd's PAL sistem:
the final format on the rip dvd is different than original:
Following the guide for dummies (yes i'm...) i'm using DVDDECRYPER, DVD2AVI TMPGENC, CHAPTERXTRACT, DVDMAESTRO AND GEARDVD 6.03
here some settings:
after dvddecrypet i'm opening DVD2AVI the format is 720x576
pressing F5 i get the info, 16:9.
tmpgenc settings for PAL
going ahed, using dvd maestro importing asset, compiling the movie and buring with gear6 i have my dvd5. here the result:
Original DVD movie on my sony 16:9
Rip DVD movie on my sony 16:9 (look bit like a zoom)
Original DVD movie on my old mivar 4:3 (with the correct black borders)
Rip DVD movie on my old mivar 4:3 (you see? is total zoom out!!!)
why the aspect ratio in NOT RESPECTED???
all the movie is stretching out, It look ridicoulos
what i'm doing wrong?
Tnx
In the mpeg setting window under video tab, set the aspect ratio to 4:3. In the advanced tab keep it 16:9. This should solve your problem.
Good Luck!
Aspect ratio problem: Converting 2.35:1 AVI to DVD w/out squishing
By Calidore in forum Authoring (DVD)Replies: 31Last Post: 1st Apr 2015, 12:33 -
Problem with Aspect Ratio in DVD Flick
By Dave_T in forum Authoring (DVD)Replies: 1Last Post: 4th Dec 2011, 23:07 -
AVCHD to DVD: aspect ratio problem
By The Realms of Gold in forum Video ConversionReplies: 7Last Post: 22nd Mar 2011, 05:05 -
Aspect ratio problem with DVD coverted to MKV
By nick1977 in forum DVD RippingReplies: 23Last Post: 16th Nov 2009, 11:42 -
authoring DVD - pixel-aspect-ratio problem
By Levina in forum ffmpegX general discussionReplies: 5Last Post: 22nd Mar 2008, 16:00
