    Nov 2002
    Singapore
    I have a Kylie.Fever.Live.In.Manchester.2002.DVDivX-KiNESiS.CD1.tar file and when extracting with with WinRAR 3.10, I keep getting file authenticity errors on every file, however I let it run and the .avi file was finally extracted from it. When I try to play it with Windows Media Player 9, it tries to download a codec but fails. The video still runs but there's no sound. Any ideas? I'm not sure what DVDivX is but I do have DivX codec installed.
    Aug 2002
    Australia
    Try getting hold of GSpot from http://www.headbands.com/gspot/ and it will be able to tell you what codec the file requires.
    If its still broken then try running it through AVIPreviewC from the software section of http://www.funkster.org which will at least give you a working AVI file.
    Nov 2002
    Singapore
    I got a ac3 codec and now everything's fine! thanks!
