Hi,
I have an MPEG2 video/audio movie. I want to change just the audio part to LPCM, keep the video and re-create the movie. What's the flow to do that. I have TMPGENc Plus
thanks,
Cau
Are you planning on putting these files into a DVD authoring program? If so, you do not need to mulitplex them back together (unless the DVD program doesn't support that but I do not see a DVD program supporting PCM without seperate tracks).
You could load the MPG into TMPGEnc and then goto File, Output to File, Wave File. -
To make sure I understand your help, I plan to do this.
Using TEMGEnc. Input: MPEG2 (video/audio), file => output to file => wavefile to extrace the Linear PCM
Using DVD Workshop to authorize. Select a replacement audio file => the wav file extracted from above which will replace the MPEG audio.
Is it correct?
thank you very much.
Cau -
That sounds correct. I do not use DVD Workshop, but that sounds right.
When you're outputing the MP2 as a WAV you are converting it. Make sure it is 48000 Uncompressed. From what I see, that is the default setting in TMPGEnc. -
It is interesting that by using LPCM audio, the final *.iso file is smaller than the one with MPEG audio. Does that make sense? I always have the impression that the compresses MPEG audio must be smaller.
thanks,
Cau
Help! How to convert mpeg-2 file with LPCM audio to Final Cut Pro?
By afireinside181 in forum Video ConversionReplies: 3Last Post: 31st Oct 2011, 18:59 -
how to convert mp2 audio to lpcm?
By gareth41 in forum Authoring (Blu-ray)Replies: 9Last Post: 21st Oct 2011, 13:47 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 09:15 -
MPEG2 with LPCM -> ? (less MB demanding format)
By Zetti in forum Video ConversionReplies: 3Last Post: 15th Sep 2010, 13:12 -
Convert DTS stream to LPCM ??
By Browncoat in forum AudioReplies: 9Last Post: 1st Oct 2009, 16:48
