How do I split a movie into two or three parts and then
be able to view each part?
What do you use to encode? If you use TMPGEnc, why don't you simply encode half the movie, or how ever many minutes you specify, then encode the 2nd half after. But make sure to rename the 2nd half of the movies file.
On 2001-08-31 17:17:36, kha5693399 wrote:
do you have a serial number for vcd cutter?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Firstly, you can't ask for serial's in this forum.
I have not used VCD cutter for Mpeg 2 as I dont bother doing SVCD's as it takes too long and I find VCD very good.
VCD cutter does open Mpeg 2 so I assume it will cut it?
<font size=-1>[ This Message was edited by: MicoMan on 2001-09-02 13:38:28 ]</font> -
the best thing to use to cut your movies is
tmpeg > file > mpeg tools > split/join
Splitting bluray movie to 2 bd-r discs
By jayt34 in forum Authoring (Blu-ray)Replies: 4Last Post: 25th Jul 2010, 19:50 -
Help with splitting
By stinger161 in forum EditingReplies: 1Last Post: 29th Oct 2009, 18:58 -
Windows Movie Maker. Blank video when splitting, trimming video clips
By rlarden in forum EditingReplies: 2Last Post: 3rd Jul 2009, 07:23 -
Splitting a Movie into two parts
By mysts in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2008, 23:25 -
splitting an mpeg-2?
By php111 in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 19:18
