i just used Smart Ripper and was able to burn Dead Alive (widescreen) version to a DVD+rw....but when i play the burned disk the movie is not in widescreen...how can i fix this?
Open the ifo file for themovie in IFOEDIT and look the line for movie,does it say movie 4:3 or movie 16:9??
Dementia,
I had the same problem, but opposite. Try this:
1) Open your main movie IFO in Ifoedit: VTS_xx_0.IFO. If your main movie is VTS_01, then open VTS_01_0.IFO.
2) In the bottom half of the screen, scroll down to "Title Set (Movie) Attributes"
3) Look at the "Video" line in this section to see if it says 16:9 or 4:3. If it's 4:3, that's fullscreen. Double click on this line, and a box should come up that lets you change it to 16:9.
4) Save
This worked for me; I don't know enough to know if it works always (still a newbie myself). Good luck.
Rip the contents of home DVDs without it locking up the whole works?
By DB83 in forum MediaReplies: 3Last Post: 5th Dec 2010, 11:40 -
Anamorphic widescreen with TMPGenc Author Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2010, 03:26 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 23:20 -
DV-AVI widescreen 16:9 movie from Windows Movie Maker.
By bagb in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2007, 11:37
