I am considering buying an usb tuner/capture card
and I don't understand what this means:
Capture rate 30 frames per second at CIF format (352x288)pixels.
I know what frames per second means it's the CIF thing that i don't understand.
Thanks in advance
VCD4ME
We were all NEWBIES once and the only stupid question is the one that's not asked?
CIF = Common Intermediate Format
CIF is sometimes called Full CIF (FCIF) to distinguish it from QCIF. -
Holy crap SHS
11 minutes and I got an answer.
that must be a record
all I did was go to the bathroom and come back.
Thanks for the quick response but can you explain what that means in laymans terms I have never carptured anything before
Thanks in advance
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
CIF is also referred to as "SIF" (i assume Std Intermediate Format?).
Course, he could be referring not to MPEG1 encoding but CD disc images, in which case CIF is the format created by Roxio/Adaptec/Cequadrat/Corel EZCD creator platinum, Videopak, WinonCD, EZCDpro and also by IAuthor. (diff versions though).
<edited by SCW>
Whoops! I didn't read all of the orig post.
Guess he was talking about encoding. BTW the VideoCD standard uses the CIF resolution. -
Sauve why did you say usb 2
Also kind of understand CIF .
So here are a couple more questions:
1.Is 352 x 288 standard?
2. Is this the best I can capture using this card?
Thanks in advance
QCIF and CIF sequences needed
By krao in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2010, 17:46 -
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 07:19 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
