I have been encoding for quite some time now. This is just of course my opinion but I have encoded 100's of films now. Panasonic Encoder produces MUCH better quality than TMPG Enc. The Panasonic Encoder does a terrific job in Picture Quality and Reducing Blockiness. Yes it does take longer (USUALLY). I do say Usually because with TMPG Enc. you can "tweak" the filters and settings to have a very long encoding time. Just for all those Newbies or people who havent tried Panasonic, give it a shot. It is well worth the money. By the way I have also tried LSX Mpeg, avi2vcd, Roxio and Nero. I bought Xing but didnt know it wouldnt run on Windows ME, so I cant rate that one.
MY PERSONAL RATINGS
(If 10 is best and go from there)
10---Panasonic
8---TMPG Enc.
6---LSX
5---Nero
2---Roxio
1---Avi2Vcd
Thanks all!!! and I know we all have different opinions!!
I agree with you on Panasonic for MPEG-1
for MPEG-2 CCE is #1
for crazy settings xSVCD TMPGEnc is #1
one question - do you every convert DivX to VCD with Panasonic? if so do you convert your audio to WAV first or have you had success without converting? -
TOTALLY agree with you there, nba_bill. PWI kicks all! its easy to eliminate blockiness and it is way easier to setup. my only beef is that the color does seem to bleed, but that can be fixed (havent figured it out tho). TMPGEnc does come in a close 2nd but its settings are horrific. if you want to turf the blockiness you have to substitute it with a very blurry picture.
MY PERSONAL RATINGS
10---Panasonic
09---TMPG Enc
00---everything else sucks my balls!
later bater. deltaboy -
hey stinky!
in regards to converting DivX to VCD, use Premiere with the PWI plugin. extract your WAV with VirtualDub. place the AVI in the video timeline and your wav in theaudio timeline. export it... NO BLIPS.
Stinky--I just automatically extract the audio with VirtualDub no matter which encoder I use---The audio sync comes out perfect--I dont even bother using the same files when encoding! Thanks
WMV encoders
By Gremlin78 in forum Newbie / General discussionsReplies: 1Last Post: 28th Mar 2012, 10:51 -
AC-3 encoders... which might actually work?
By takearushfan in forum AudioReplies: 5Last Post: 22nd Dec 2010, 20:54 -
about mpeg-2 encoders
By sgbd in forum Video ConversionReplies: 6Last Post: 11th Sep 2010, 07:02 -
encoders?
By just in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2008, 09:15 -
Encoders and Quality?
By video_enthusiast07 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 10th Jun 2007, 19:27
