  1. Ripped dvd onto hard drive and have following files;
    VIDEO TS BUP/IFO
    VTS 01.0 BUP/IFO
    VTS01.0 VOB - MENU
    VTS 01.1-5 VOBS - FILM
    Can anyone tell me the best way to get rid of the VTS01.0 VOB - THE MENU.
    I have an excellent guide from the forum using ifoedit but it tells me to go into vob extras and tick strip streams, correct vob-unit pointers, correct ifo tables and create new video ts ifo folders etc.
    I have used this method for stripping the film but do I have to use this method just to get rid of the menu or is there a quicker way?
  2. timmy4,
    Not to be a smart-arss, but To delete a file, just highlight it, press the DELETE key on your keyboard. Its GONE.
    HaHA, your post is so vague, what do you want to do? Do you want your movie to Autoplay when inserted into your DVD player? No, menu at all to show up? Do you want to kill extras and have the original menu, but kill the buttons to the deleted files? The answer to your question is most likely in the forum already, SEARCH.... But to ask for help, then be specific.
    VidHack
