Ok, I carefully followed a guide to backup my Monsters Inc DVD by using decrypter to rip, ifoedit to create new files, and Nero 5.5.9.9 to burn, however, the DVD-R will not play in my standalone. BUT, when I put the DVD-R in my computer, WINDVD automatically starts and plays the DVD. What am I doing wrong? Thanks!
Standalone: Toshiba SDR3750
Burner: Toshiba SD5200
Media: Imation, version 2.0
Burned at 2X
Live Long, Play Hard, Think BIG!
Try use something else to burn with like Recordnow Max, Primodvd or instant dvd. And be sure that your dvd player support the media you are using.
http://www.vcdhelp.com/forum/viewtopic.php?t=132574
http://www.vcdhelp.com/forum/viewtopic.php?t=134909 -
I just had the same problem when I was using what everyone had recommended in this thread - http://www.vcdhelp.com/forum/viewtopic.php?t=127624&postdays=0&postorder=asc&highlight...ysical&start=0
But I figured out my own settings that would work with Nero 5.5.9.17.0 and my DRU500A that would play on my new Panasonic CP72:
DVD-ROM UDF/9660
Check ISO level 1
Check IS9660
Uncheck Joliet
Uncheck anything in "relax ISO restrictions"
UDF 1.02 (under the UDF tab, select physical)
DVDMax, DVDxcopy, and DVDdecryptor work fine for me also. -
It is also dependant on the brand of media I have found. DVD players do not use the same sophisticated error correction and read technology that the DVD drives do. You might find that a different brand of media is needed for your set-top player to work. My old Pioneer (DVD-343) couldn't read the 2x Princo that my newer Philips can.
Good luck w/ ithttp://encoding.n3.net <-- for all your DVD and CD backup needs! -
To Baldrick and everyone else that has helped me in the last couple of trying days.......THANK YOU, THANK YOU, THANK YOU!!!!!!!! I really can't thank you guys enough. My wife and boy thank you too! I was driving everyone nuts this weekend when my Toshiba burner arrived at my doorstep on Friday. After several hours of fumbling through the guides and asking questions here at VCDhelp, not to mention four- $4 coasters (Imation 2X's) I FINALLY made a successful backup of my Monsters Inc. The problem you may ask? NERO! No more NERO! I used RecordNowMax and my DVD-R burned successfully. Once again, thanks to all those who helped and thanks to such a wonderful website!
RETAIL DVD plays in standalone - "No Disc Inserted" message in PC
By prattitude in forum Software PlayingReplies: 6Last Post: 28th Nov 2007, 12:07 -
Standalone Player plays only 33 mins of the resulting DivX DVD
By penguin74 in forum DVD RippingReplies: 8Last Post: 30th Oct 2007, 17:25 -
Burned DVD plays OK on standalone - not on PS2!?!
By offensekilla in forum Authoring (DVD)Replies: 5Last Post: 31st Jul 2007, 11:07 -
DVD (ISO) Plays Fine on PC, Won't Play on Standalone
By MoneyAddyct in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2007, 21:15
