  1. Hi, I tried to play a burnt VCD on my DVD player and the player didn't recognize the disc.
    I used TMPGEnc to encode the source to a standard VCD format (352*240 NTSC 1150 Kbps etc...) I then burn the mpg-1 to a Cd-r (Memorex) using Nero 4.XX.
    My player is a Denon DVD 900 and is supposed to play VCDs. However it is said in the documentation that it only plays Cd-R wich contain audio/mp3 data.
    Is there a brand of Cd-R that are better or a trick to enable it to play my VCD ?
    And how the player can differentiate a Cd-R from non Cd-R ? Is it a code or a special track or the way data is encoded?
    Thank You
    Jan 2003
    Best Coast, Canada
    Try burning your VCD with VCDEasy.
