Hello. I've followed Steffy's guide to do a DVD to VCD conversion. The problem is that I want to add to the VCD pemanent subtitles (as I've done previously when I converted DivX to Vcd). I've tried to do the intergral conversion (using the DVD2AVI's dv2 file on TMPGenc Plus) and then I've opened the mpeg file with virtualdub and add the subtitle (with the video plugin subtitle). Then I've done a frameserver and re-convert it again with TMPEnc. Well, the first problem is that the file frameserved with vitualdub is bigger (much bigger) wich is a little bit odd (because they are all mpeg files with the same quality). The second one is that the subtitles aren't coordenated with the video. Is this because of the MPEG conversion that virtualdub does when opens the first created MPEG file (from the dv2 file)? Is there other way to do this conversion (I've tried to open the dv2 file directly with virtualdub but it doesn't work.
Please help me...
Antioch
Results 1 to 1 of 1
Add permanent subtitles to S/VCD,DVD,AVI with ffdshow/vobsub
By Baldrick in forum User guidesReplies: 74Last Post: 4th Oct 2011, 04:11 -
How to insert NON-PERMANENT subtitles to a DVD?
By CrisLark in forum SubtitleReplies: 2Last Post: 9th May 2009, 14:27 -
Questions about few things. DVD to Divx with permanent subtitles, etc
By Earthling2000 in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2009, 13:15 -
Permanent subtitles
By Jomapil in forum SubtitleReplies: 3Last Post: 15th Nov 2008, 04:24 -
Help encode permanent subtitles and then edit DVD
By kapital in forum Newbie / General discussionsReplies: 11Last Post: 29th Apr 2008, 09:43
