Hi,
I'm looking for a way to extract clips from DVDs and convert them to divx in the same way that VirtualDub converts MPEG-1 - i.e. a preview window which can be navigated frame by frame, allowing me to cut out unwanted parts (eg adverts) and mark in and out points, then convert the selected area to divx.
Is there a way of doing this, or would I have to rip the entire DVD first then use VirtualDub?
Thanks,
Paul
It isn't considered 'PC' to own a Mac
Try this
http://www.vcdhelp.com/forum/userguides/135262.php
Smartripper in "file mode" to choose what you want, then DvdX to preview before you canvert.
Editing audio on DVDs and BD
By tolson12390 in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2012, 15:49 -
MOV: Editing: Joining/Cutting/Splitting software
By taboo in forum EditingReplies: 5Last Post: 8th Aug 2011, 19:59 -
editing video - cutting a few minutes at the beginning and end
By hardy in forum Newbie / General discussionsReplies: 6Last Post: 30th Jun 2010, 18:19 -
H264 Editing and Cutting - Apple h.264 settings needed
By bsti in forum MacReplies: 0Last Post: 17th Nov 2009, 08:27 -
Cutting a M2V file or editing SINGLE FRAMES of it
By lorix in forum EditingReplies: 3Last Post: 13th Nov 2008, 04:05
