Folks,
I thnk i've tried everythig. Can someone please help?
I want to:
convert an .AVI to SCVD (mpeg) using CCE in Adobe Premiere 6.5
I tried using CCE's templates, but when I want to Burn the SVCD, I get
an ERROR when I use "NERO"
Nero says that there is some "stream error"
Thanks for reading,
any help would be appreciated
medudder
Basically it is not possible to do it staright ahead, but you will not need much extra effort:
Set up all parameters in premiere/CCE according the SVCD standard.
Force CCE to generate separate streams for audio and video(NOT program stream).
Multiplex(MUX) the resulting 2 streams into a single file with a program able to generate correctly the svcd format, like BBMPEG, or TMPEG.
Are Premiere processing "byproduct" files erasable? Need advice!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2011, 16:58 -
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 13:01 -
Guide wrong? "Converting a PAL DVD to NTSC using CCE"
By OliverGrey in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 01:47 -
"Unsupported audio rate in file" Message in Premiere Pro CS3
By JustinBaker in forum AudioReplies: 2Last Post: 23rd Mar 2008, 23:27 -
Blurred or "glowing" highlights in Premiere PRo
By wturner in forum EditingReplies: 7Last Post: 27th Sep 2007, 02:06
