Hi
I have a load of music videos (.vob's) that I would like to burn to DVD-R - also creating motion menus along the way - but the few programs I have refuse to recognise the vobs - instead they seem to want mpg files (mpeg2)
What program should I be using?
All help gratefully received
JF
DVD authoring software is designed to work from elementary streams. You need to demuliplex the vob' into there m2v and ac3 streams.
Ifoedit will create ifo from vob's. -
ifoedit will create ifo's? never did it for me...
not when their missing?maybe try to use other
kind of ifo from other files maybe?then use ifoedit
to create new ones?not sure really -
Thanks wulf109 - I knew that it might be something like that. I have already tried this using Flask - but boy is that slow. I have heard that I could get it to use CCE but am unsure how to get this to work - is there a guide out there that will show me how to install CCE as a plugin for Flask. I know you can do this for Adobe Premiere - but not for Flask.
I tried IfoEdit to create the ifo's - Could not find any VOB unit in VOB files was the error I got.
I think the best way to do this is to Demux - but I want to be able to do it faster than Flask seems to be able to do.
Any more help will be appreciated.
JF -
good thought musher - but how - I am pretty new to this.
So that you know what I am dealing with here - they are vob files created from TV captures.
Any ideas?
JF -
I'm wondering if these VOB's aren't actually just MPEG's with the extension renamed. There's more to VOB's than just a muxed A + V stream(s).
The prudent thing to do would be to rename to MPEG temporarily and demux w/ TMPGEnc. If it doesn't even accept it, it probably is a VOB (or could be corrupt
). If it does, take your elementary streams and Author in one of the usual progs (see Left <--).
Burn - VOB without IFO & BUP files?
By Miss Sherlock in forum Authoring (DVD)Replies: 25Last Post: 24th Aug 2009, 01:20 -
Burn VOB without BUP IFO [Special]
By ron007 in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2009, 21:01 -
Trim VOBs to re-burn to DVD
By ehmjay in forum MacReplies: 7Last Post: 16th Nov 2008, 17:59 -
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2008, 00:02 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 11:39
