My PC is s P4, 1 gig mem, video card with 128 meg meg. 7200 rpm IDE Drive with 20 gig free. Use Pinnacle Stuido 8 and their capture card.
I want to purchase a DVD Burner. I know that no burner will produce DVD that will work on all DVD players. I have heard tha HP come close.
Can anyone tell me the best one that does the best at making DVD that will work on the most of Players.
Jim
Not sure if it work on most players, but my Sony DRU-500A is very nice burner and it support + or - format. So if player doesn't play one you can still burn other.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Just a quick note - if you burn a disk with your new drive, and it won't play on your player, try some different types of burning software. I went through Nero and DVD Decryptor, before I found PrimoDVD that would actually work with my player.
Where can I find PrimoDVD ? Didn't Sonic bought it and renamed it or something ?
Donpedro,
The company is called "Stomp" and the program is called RecordNowMax. You can do a search on this site and it's mentioned very favorably in several posts. If you buy it, it sells for like $40 at stompinc.com. I'm sure there are other methods of getting it, but I wouldn't know any of those.
RecordNow Max !!!
Now I know what are you talking about
Best DVD BURNER?
By nj473 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2010, 19:40 -
New DVD Burner
By pepegot1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Feb 2010, 00:57 -
What DVD Burner Do You Use?
By Ray&Paula in forum DVD & Blu-ray WritersReplies: 6Last Post: 20th Mar 2008, 02:01 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
burner not seeing dvd
By SiberSan in forum ComputerReplies: 1Last Post: 1st Oct 2007, 13:46
