My Philips DV910 can play VCDs but SVCDs are no good, is there anything i can do at all to make them play, or can i make VCDs with the same quality as the SVCDs?
Do a search through the forums for "header trick" or "VCD header trick" or "SVCD header trick" you will get many hits and most will describe how to do it. Basically it ends up producing a SVCD file with a VCD header (so technically you are producing either an XVCD or XSVCD.) This type of file can be played in many standalone DVD players that only play VCDs.
I tried the header trick today. I used TMPGenc but it gave me errors when I tried to convert it from mpeg 2 to mpeg1.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
